		Steve Tittle
Well I did it and it didn't take long, tried to give advice and exhausted my knowledge in a hurry.
Building a computer from the ground up and need some advice from the guru's lurking around the corner.
To start with this is where I'm at:
ATX mid tower with 3-5 1/4" externals, 2- 3 1/2" external, and 3-3 1/2" internal bays.
Dual P 2 motherboard up to 300 mhz processors
onboard SCSI and the usual IDE connections you probably know the rest.
128 sdram installed so far along with a floppy installed just for good measure.
I understand win 2000 and nt 4 support dual procs but I would like some other thoughts as far as hardware and software that will keep me on the right path (I like to wander too many foreign substances in my youth I think).
I am all ears!!
I am all ears!!
  Also see how fast the board can go with Celerons.  Even if it doesn't say "Celeron" in the manual, there will probably be an update (flash upgrade perhaps) at the manufacturer's website.  You have an LX board meaning it's only going to manage a 66Mhz bus which means you can only add a PII up to 300Mhz...but you might be able to stick two 500Mhz celeron processors in there for dirt cheap!!!!
