Computer cd:s on a Audio burner
  • Thread starter Thread starter Stegen
Stegen
Is there somebody who knows how to do a audioburner (Philips CDR-880) to accept data-cdr:s. I have heard that this could be done and that its easy. Is it whitout tools or must the box be open?
Sorry for my bad english
Stegen,
I just did alot of research about CD burners because I wanted to be able to burn audio CDR's and CDRW for computer data.
Everything I read indicated that the audio DC burners (like you have) will not accept the less expensive computer CDR's. The technology is completely different. That is the disadvantage of the dedicated audio only CD recorders...the CD's to record on are much more expensive to produce and buy.
Unless something major has changed technology wise you are stuck using the more expensive CD's to record on.
Thats a big reason I did not look at the audio only CD burners/players.
The tecnology is NOT different between audio and data cd's. But the record companies opposed cd's being available to consumers because of the possible loss of buisiness due to copying. So when the first recorders came out, the deal they cut with the record companies required the cd-manufacturers to send the record companies a royalty payment on each CD-R sold. The only way to enforce this was to put a bit of computer data on the music discs that identified the disc as being a Music Cd. The data discs lack this identifier and so an audio burner won't recognise them. But other than this bit of computer data the technology is identical. I have heard that there are ways to get around this, usually by prying the door open after it has read the TOC but I can get a 15-pack of music cd's at Sam's for $7.50 so thats not expensive enough to get me to do that. I think a case can be made that audio burners, being designed specifically for audio, might do that job a little bit better. Also a little bit of trivia. The way a consumer cd is recorded is different than commercial cd's whether data or music. In consumer discs, there is a heat sensitive dye that changes color and so reflectivity when heated. Consumer burners don't actually burn pits and lands when they burn. They just change the reflectivity of the dye. Interesting.
