Compressor Tutorial
  • Thread starter Thread starter theshaggyfreak
T
theshaggyfreak
Now, I know a little on the basics of using a compressor, but I would like to study up on it a bit more. Is there something out there that's not too lengty of a read that would give me some basic rules for setting up a compressor for different instruments? Guitar, bass, vocals, etc.
Come to think of it, I could use the same for EQ. I'd be very thinakful if anyone has a website or knows of a book that I should be reading.
I know a lot fo it is trial and error, but I figure studying up on my craft a bit more would help in the long run.
Mistake???
Hi
I read the above article and I think there is a mistake, but I could be wrong as I'm just learning about compression.
The author states that in Figure 2, a 2 dB rise in level at the input results in a 1 dB rise in level at the output. This is fine, but in the next paragraph the author says "if the output goes up 2 dB for every 1 dB increase in level at the input, then we have a 2:1 compression ratio."
According to this, Figure 3 is wrong. If the latter were true, the gain respose in Figure 3 would be mirrored about the dotted line (gain = 1). However, Figure 3 shows (looking at the 2:1 ratio) a 1 dB rise at the output for every 2 dB rise at the input, not the other way around as previously stated.
So, which is it? Is a 2:1 ratio equal to a 1 dB rise in output for every 2 dB rise in input?
Thanks
Looks like a typo (or maybe a "braino") in an otherwise excellent article.
It should say, "if the output goes up 1 dB for every 2 dB increase in level at the input, then we have a 2:1 compression ratio."
You get a gold star.
I noticed that too when reading it, but I wasn't sure if it was just me or not.
Yea, a great article!
