singlespeak
Oh my, I can turn it off. Good.
Nevermind!
Thanks all =)
Nevermind!
Thanks all =)
That's why people don't throw birthday parties for me anymore.It's kind of like using the garden hose to put out a candle![]()
Yes it's frustrating isn't it RAMI. If only I could be as savvy as you.Oy vei.
Yeah, I know the feeling. It's the same thing here, except I started using my own "hose" instead of a garden hose, if you get my drift. That somehow seemed to offend more than a few people....That's why people don't throw birthday parties for me anymore.
They automatically push up the volume by an amount proportional to the amount of gain reduction applied in the compression stage. Theoretically this would mean that - if it were a linear relation - when you set the gain reduction ratio to infinity-to-1, it would supply an infinite amount of makeup gain and send the signal level up through the roof,
On paper, brick wall limiting is by definition a ratio of inf:1. If x>0 dB over threshold in = 0 dB over threshold out, that's infinite compression.Except that gain reduction isn't infinite with a ratio of ∞:1, it's equal to the amount the signal exceeds the threshold. If make up gain is tied to gain reduction then 10dB over threshold = 10dB reduction = 10dB make up.
I know that in the physical world that what we call "brick wall limiting" really doesn't meet that ideal, some signal usually manages to eek through, but I was talking theoretical definition, not physical circuit design shortcomings.
And I believe the automatic makeup gain is not tied to the number of dBs lost in compression, it's tied to the compression ratio setting. Correct me if I'm mistaken about that, but none of the ways I can think up that it would have to work if it were tied to the actual signal and the actual decibels lost make any sense to me.
Finite when using number of dBs as the scale. Infinite when using ratio as the scale.But "infinite compression" still equals finite gain reduction, and if make up is tied to reduction it will be finite as well.
If you're talking a dynamic, peak-by-peak adjustment, the results would be a zero-sum cancellation of the compression; the output would equal the input. So that's out.To tie it to reduction would be a matter of looking ahead, finding the peak amount of reduction and plugging that number into the make up gain.
This indicates that the pre-compression signal itself is not the factor on which the amount of makeup gain is calculated, because the signal did not change. All that changed was the reduction ratio. And if the look-ahead were post-compression, the peak output signal would stay the same, not increase.So I added a compressor and I was fiddling about with the controls and at one point I noticed that when I increase the ratio from 3:1 to 15:1, the volume actually peaks higher!
That's what we're talking about, just how the auto-makeup actually works. It drives everybody nuts.Betting it has auto-makeup…ridiculous novice feature… drives me nuts.
Lol! Yeah, probably.Betting it has auto-makeup….
