Hey Guys and Gals,
Just to inform you all that New Years Eve gig was a smash and man, what a full house.
Recordings I've done with CEP came out great and there was enough botton end to blow them away without destortion or low bottom hums. You see, I seperate my instruments into two sections.
1. DRUMS AND BASS on Right Channel.
2. STRING, GUITAR, PIANO ETC... on Left Channel.
This gives me an overal total control. HOW?
EASY!!
I'll try and explain the best I can OK?
First, You may think that just having DRUMS AND BASS on the right Channel doesn't give you much control RIGHT? But that is not correct, In fact, your total control comes from your stage mixer where you can either bring forward CYMBALS, HIHAT TAMBORINES and all the high signals or set them further back by using the Treble. The secret I found with the SNARE, TOM1 and TOM2 works with the Middle frequency but treble gives them the presents as well. I use the mids to lower or raise their volume and presents. The Bass frequency allows you to bring the BASS more forward to the front or set it further back (depending on what you like).
Secondly, The same as above is also related to the left Channel of your recording where you have all the little finner bits such as STRINGS, GUITAR, PIANO, ETC....
If you don't have a stage mixer but would love to have one, I'm sure that there are many none-amplified second-hand mixers out there. I've picked
my 12 channel mixer up for under $100.00. It doesn't have a power amp' with it, but it sure does the trick when I plug it into one.
If you have midi files that you want to record into CEP, then if you also have a midi editor. Record each individul instrument into CEP and edit them to your likening. When editing my wave tracks (which I recorded from midi), I use mainly the | Effects | menu option.
Another great Idea I've found is that, if you have the original mp3 or wave file of the song you really like but can't get all the voices out of it, Simply load that song you want and do a little copying and mix paste into your midi file that is now a wave file. Be sure that the original and midi is in the same key and tempo. This way if you like an intro what the original song has and you want that intro into your own wave file, you can copy the original and Mix-Paste it intro your own wave (recorded midi file). It took me to do a song with harmonies and all the guitar licks at leat 4 hours. This song is Abracadabra from the Steve Miller Band. It was worth all the work and now I have a complete and great sounding backing of that song. If you have that song in mp3 format or whatever, play the song and listen to the gaps where there is no main vocals, you will find that it has a lot to offer as far as getting a true backing by using CEP.
