J
jaynm26
Why is it some set the threshold "BELOW" the actual signal??? I have no idea Why some do this. I always saw the thresh as the ceiling the actually parameter of the comp that nothing should pass meaning wherever you set the Thresh it should be above the signal not below it...
Uggghhh!!! Just when I thought I knew everything about compression
please explain your technique of doing this so I mean learn
