noodles2k5 said:
I've been playing around with software compressors, but I don't notice a significant difference in levels. Is there some kind of graphical tool I can use to squash the peaks in my bass guitar track?
I assume you'd better learn to use compression right... Do a search in here for compression, and you should be able to read a bunch of good tips...There are graphical tools where you can determine any compression curve, but you end in the same problems: either you use the compression (timing) settings with these tools, or you simply distort the sound (which can be a very easy way to enhance a bass track!!! You might try a tube emulator or so with some distortion - I like that quite a lot). IMHO, the only 'halfway graphic' tool would be to manually adapt the volume track in your DAW to ear (and maybe eye) -- if possible... But I don't work that way, so someone else might be better help.
noodles2k5 said:
Would I get a the same effect if I normalize to a certain level? I know visually, the wave would get squashed... but since I don't know what good compression sounds like, I can't really compare the sound.
No, normalization is something completely different. You MIGHT try to normalize every single note, but that COULD work only, if you don't have any overlapping notes... There are books that may help alot in starting to mix, that have CDs with them. Alas I only know some german ones...
noodles2k5 said:
Or how about a limiter? That would get rid of my peaks, eh?
That is a special case of a compressor, but might work easier, as you have one parameter less to adjust... I often dislike the limiters, as they tend to be a little drastic in their changes... But it depends a lot on what you're trying to achieve: are the peaks just the attack of the bass or is it inconsistent playing?
And BTW: don't ask for the 'right' compressor settings - they depend on your track, taste a.s.o.!
aXel
