All though Im deaf I will take a stab here. Mix one was mixed form computer to a analog machine and limited with outboard compresion.
Mix two was all in the box.
Both were summed in the box, but took an out of the box trip. You're close, and not as deaf as you think...
It seems to me that Mix A is a bit punchier...Did you bring the drums out a bit more on that mix?
Both mixes were created at the same time so, no, the drums were not different on one vs. the other.
Will my analogue comment come to bite me in the ass?
Chomp-chomp...
Okay. The project was all tracked direct to hard disk at 24-bit, 48kHz. There are 5 songs in the project, and each song averages about 23 tracks. Tracking occurred over 3 nights. We are doing take selections at a distance. Rough mixes like the one above are for the band to listen to to confirm that I assembled the right collection of takes. So for fun I took a stereo sum in Cubase and ported through two outputs on
my Yamaha i88x, and right back in through a set of inputs to a new stereo track in Cubase. I took the same stereo sum and also ported it through
another set of outputs on the i88x, and then to my
CRL SEP400A multiband dynamics units and then to the Tascam BR-20T...I setup another new stereo track in Cubase and tracked recorded the output of the BR-20T in realtime during playback of the stereo sum from Cubase. That's how I got two versions of the same mix: one, a simple D/A/D trip through the i88x, and another the same except also going through the CRL units and the BR-20T.
The tracks in Cubase are totally raw except for the ambiance tracks (the reverb you hear), which are actually a couple mics that were thrown on ground in the large hallway outside one of the tracking locations...I did a steep shelving cut on those at around 200Hz to reduce the mud so the rest of the mix was easier to hear (again, because the mix was a rough for the band to approve take selections).
The BR-20T hasn't been calibrated nor is it setup for the tape I'm using, and the CRL units need calibrating too but this experiment helped me learn and understand more about how I'm going to do that...the input sensitivity is off and so there was some crunch there because the input was a little too hot for them...the CRL units were set pretty conservatively with a little low end boost but everything else was flat.
I'm not trying to make excuses, I'm just wanting to clarify the stage of what you are hearing...it is all far from polished, but promising AFAIC...
SO...
The CRL/BR-20T version is mix a, and the simple i88x output to i88x input is mix b.
At this point I am looking forward to getting the CRL units dialed in better as far as input sensitivity, and maybe trying some other opamps in them. Currently they have 4558 chips and I'm interested in trying 5532's or 2134's...and recapping them. I've heard enough from them to know that I like them.
So Herm was just about right on except that mix b was not totally in the box, although it basically was for all intents and purposes...it just had a superfluous D/A/D trip.
