CM Labs Motormix who uses this?
  • Thread starter Thread starter Teacher
Teacher
Teacher
wondering how well it worked with DAWS.,....specifically Samplitude and Sonar...you can buy others to increase the channels as well right?
could u also insert plug-ins and control the settings etc.?
i have one and use it with cubase vst 5.1 - it works quite well, but it´s possibilities are a bit limited. the buttons to the left and right of the faders aren´t functional in vst initially - you have to run a little helper program in the background to get them working. for further vst control capabilites look at the list from steinberg below.
in fact it´s primarily designed for pro tools and there it really shines - at least that´s what i heard! i think i also heard somewhere that sonar and samplitude both support the motormix but i cannot comment on the degree of integration, sorry! maybe there´s also a list like the following from the other manufacturers?
cheers!
fretless
CM Motormix as a VST Remote Device
Fader: Volume
Solo and Mute: Solo and Mute
Select: Channel Select
Write Control: Monitor enable
The Rotary Control Section is assigned to control the following VST parameters for each channel:
Display Parameter
PA Pan
S1 Effect Send 1
S2 Effect Send 2
S3 Effect Send 3
S4 Effect Send 4
S5 Effect Send 5
S6 Effect Send 6
S7 Effect Send 7
S8 Effect Send 8
E1 EQ 1 Enable
F1 EQ 1 Frequency
O1 EQ 1 Q Factor
G1 EQ 1 Gain
E2 EQ 2 Enable
F2 EQ 2 Frequency
O2 EQ 2 Q Factor
G2 EQ 2 Gain
E3 EQ 3 Enable
F3 EQ 3 Frequency
O3 EQ 3 Q Factor
G3 EQ 3 Gain
E4 EQ 4 Enable
F4 EQ 4 Frequency
O4 EQ 4 Q Factor
G4 EQ 4 Gain
The Effect On/Off Controls is assigned to control the following VST parameters for each channel:
Button Parameter
equaliz EQ Active
eff-1 Insert 1 On/Off
eff-2 Insert 2 On/Off
eff-3 Insert 3 On/Off
eff-4 Insert 4 On/Off
The View left and right buttons will scroll through the VST, Group, Rewire and VST Instrument Channels.
The following controls have no assignment:
Write Controls' mode switches
Effect On/Off Section's dynamics, delay abd special switches
Left and Right Function Switches
Bank and Group switches
