grimtraveller
If only for a moment.....
A most eloquent, balanced and well rounded defence, mate.
Well, I check my mixes in mono and never have the problems you're talking about. You are talking in extremes. Saying "I mic the kik because I don't see the overheads as just cymbal mics" is talking in extremes. It's not only one or the other. Do you not work with toms, hi-hats, a snare, etc....? Or are you just trying to "win" an argument which I didn't even think this really was.
Sounds like you're the only one getting all uptight and trying to preach to someone who said they agree with a lot of what you're saying. You need to calm down and not get so defensive. I made it clear that everything I was saying applied to ME and works for ME. But hey, knock yourself out, it's your heart attack, not mine.![]()
OK, now you're just being petty, trying to find anything you can hang your hat on. I do think overheads should capture most of your kit...like about 98%...or maybe 95%...or about 93%....OK?![]()
All that works fine on paper, but doesn't always apply in real life. If my kik mic is out of phase with my overheads, then flipping the polarity works fine. I usually have to do it with my snare and sometimes on the kik. So does lining up your tracks in your DAW for those who prefer doing it that way.But I have never had a problem with the kik being out of phase in the 2 overheads. I don't mean it's never out of phase, I mean it's never caused a problem when mixing the style of music I play and mix. Please feel free to go listen to a drum track of mine and tell me which way the kik is leaning. There's a difference between "ignoring" a problem and actually "having" a problem. Nobody's ignoring anything. If there is a problem, I address it.
Like I said, I used to take the time to center the kik in the overheads with Glyn Johns, but found that it doesn't make a difference when I mix. Again, I'm talking about what works for me. I'm not telling you to change your approach to anything.![]()
And please show me where I said what you have there in quotations.
Dude, I'm simply responding to some of your statements.Checking mixes in mono is not what I'm talking about
it will always affect the mono close kick mic when summed together if that little bit is offset.
I'm beginning to think you're arguing with me the way you are because you just don't understand the concept of what I'm saying.
Nice try. I see what you're trying to do there.
Seems to me that, unless my kik drum is 3db louder in one speaker than the other, there shouldn't be an audible difference. I actually find that hard to believe, but that's what the article says. Am I mis-understanding this? If so, I'm open to having it explained to me. I'm not being sarcastic, I'm serious.so I decided to calibrate the changes to 1/10th of a decibel, so that I’d be able to really pick out the subtle differences in localization that were going to happen when the levels between channels changed. However, I was very startled to discover that the phantom image didn’t seem to move at all even when the levels between channels changed a whole decibel! I was so startled that I became positive I had made a mistake when preparing the tape! A little investigation....showed me that I hadn’t made a mistake, and when the dust finally settled I had found out something quite interesting: that as long as the difference between channels is less than 3 decibels, the phantom image hovers pretty much in the middle point between the two speakers.
..Here's the link for those who are interested. The article talks a lot about using the HAAS effect, among other things: Moulton Laboratories :: Principles of Multitrack Mixing: The Phantom Image
is the Haas pan effect swamps the small level differences from the distance loss.Dude, I'm simply responding to some of your statements.Mo Facta said:it will always affect the mono close kick mic when summed together if that little bit is offset.
No, I get most of what you're saying. But when I'm skimming through a long post and pick up phrases like "sum to mono" in a sentence, I assume you're talking about listening for phase issues in mono.I meant when you sum the close kick mic to the stereo overheads, not summing to mono. I really do feel you're not getting what I'm saying.
Yes, but I have also seen people line the kik up too. I guess you can say any 2 mic configuration is just a creative spaced pair miking, but the Recorderman and Glyn Johns have that one mic pointing straight down at the snare, which is their "trademark" I guess.Regarding the Glyn Johns method, it has always been described as one OH being centered above the snare and the other firing over the right shoulder to the same spot on the snare. Am I correct?
Yeah man, it's all good. I think we both thought the other one was getting uptight at one point, but it's just a difference in approach/philosophy. I might have even learned something.So, after all is said and done I would like to say I never meant any animosity and merely was trying to get my point across in the most straightforward way possible. I hope you can see now where I'm coming from.
