phriq
Freon Productions
Can you take a screenshot of your DAW showing the wave so we can see the difference between strumming and palm muting?
Umm, am I missing something?
Turn down the gain until it doesn't do that anymore.
/wipes hands on pants/
This- and/or, you haven't said yet if you have the mic/line input on the interface at minimum or not.I"m talking about in your Recording software , any recording software is going to have a recording level , in many it is set by default to 0db which is too hot .....
Bottom line- you need to lower the record level. If it's already all the way down and can't handle the line out on that amp- then the s/c may not be cutting it.
The gain is on about a 5, man. Much less and there wont be any distortion left on this thing. I'm already at that line this amp has drawn where its either some or none. I've never had this problem in any other studio, but we were mic'ing the amp too though in those instances. Even with my Blue Voodoo and Krank Cab turned better than halfway up I never had this problem.
Thats what I'm afraid of. Cuz when I take the chord out of the recording out on my amp, this thing is barely audible at all. I literally cant turn it down much more without turning it off. And I dont think the recording level on Reaper is the problem, because I would still be getting those big spikes because thats what my amp is sending to it..
Well then the problem is your card, bro. You've got no overhead at all. I don't know why you think a mic and a mixer is going to help with that. You can get into a stereo interface for under $100.
You keep talking about the amp. The recording input! It should be able to handle a little bit of 'line level set minimum or what's the point?
I thought maybe a mic would record them better. Someone earlier mentioned that they had better luck with a mic.
And i guess im just scared that an interface would do the same thing its doing now just because it seems to be the line out signal thats doing this. But i know little to nothing about this stuff and i dont really have the money for trial and error. I can do that trying different techniques and ill sit and play with settings and stuff if thats what it takes.
And im sorry but i dont guess I understand what youre saying. /:
I sympathize with your fear of wasting money. For that reason, don't buy a mic or a mixer.
As nice as a Fata1ty soundcard is, it is not designed to record music. If you want to get different results, you're going to need to try something different. Get a two-channel usb interface. Your mixing will get done on the computer in whatever DAW software you choose. Reaper is free to try and cheap to buy.
Hang in there, OP. You're in the right place.
Yeah Reaper is the program Im using now. I plan on buying it when my trial is up.
Any thoughts on a good interface then?
