R
Ranman
I am considering buying a 788. I have not found any info if the 788 has an internal click track. Help please.
It can take up a track, which is usually the way I do it...losing the track hasn't been a problem for me. I believe you could also just feed the drum machine into an input if you've got an extra one available - but this would require the use of MIDI to sync everything up later.Farview said:The metronome is the click track. you can also set up a drum machine to be your metronome and record it onto a track, but that takes up a track.
