B
Brackish
Just wondering if anyone has compared to see
if the front side sounds the same as the back
side?
side?
petimar said:Haven't tried any of the Chinese Ribbons, but on a Royer R121, the back side is brighter than the front. I use the backside more often.
Keep in mind that you need to actually record the mic and compare the recordings to get a true assessment of the difference between front and back. If you try to judge them by listening live through headphones while singing or speaking into them, the test will be fairly meaningless.punkin said:The single ribbon unit seems to have a bit more proximity going for it on the front than the back and seems a tad bit darker on the back (this is when up close) back it off and I'm unable to detect a difference.
