sweetnubs
I agree it can be a tool but you are now using it ( a compressor) as an outboard effect box, not as a compressor for dynamic range reduction. If you at all blend the uncompressed with the compressed signal the dynamic range now remains unaltered. You are looking for the effects of compression, how it alters the sound envelope, i.e. how it changes the attack, release, rms, the introduction of transformers, vca's etc. etc. etc. Let's just call it what it is. The same would occur with using eq which is again why we don't use aux. sends with outboard eq. Let's say you eq a signal, then blend it with the unaltered original signal, you effectively undo the eq by doing this. Same with compression. However if you blend it so that the eq'd signal is very hot relative to the unaltered (so it's not very audible) then effectively you are just eq'ing the signal. Of course if the eq colors the signal in some other way, i.e. due to signal path construction then you are using the eq as an effect box. This is analogous to using parallel compression. I agree you may like the way it sounds but you are not really using it for reduction of dynamic range again unless the compressed signal is very hot relative to the original signal so the original signal is almost inaudible. If you are blending the two equally you are really just liking the sound because of the artifacts introduced by the compressor blended with the unaltered sound, i.e. it is now essentially an effects box. Nothing wrong with this but again just call it what it is.
Another example, say you have a wild snare hit. You wish reduce dynamic range so this hit is not to loud relative to the others so you compress it. Now blend the compressed signal with the uncompressed signal almost equally. The wild hit will now be back. The tone of the snare may now be altered though and you like the new tone coming back from the compressor. This could be for a multitude of reasons: the compression element, transformers, mild distortion, action upon the sound evelope due to paramter settings, tube saturation, etc. etc. Now you really dig the sound but the loud hit doesn't bother you so you blend the two signals for what you perceive to be the perfect sound: you've just use the compressor as an effects box. I do this often, sometimes I just like the sound of a 160vu on a snare so I'll patch it in and set it for very light compression (the box is fast) just because I like the sound of the action of the compressor on the signal. I've just use the compressor as an effects box without blending, not really to tame dynamic range. By being able to blend the "wet" with the "dry" you may get a little more flexibility with parallel compression but you can generally acheive the same "effect" by altering compressor paramters without resorting to blending. Each method works but it is not really compression because dynamic range is not being altered. (well in my case it technically is but not the purpose of the procedure)
oh a note on doing this with digital compression in a DAW: if you are not delaying the original track relative to the latency introduced by the plug-in on the compressed track you may be introducing a delay which causes phasing and which may in turn be perceived as "thickness" which is probably really nothing more than compression artifacts combined with delay and blended with the original.
