DDev
Ethan Winer said:Boogs,
> What makes the Mondo traps so much better? <
We add a membrane to the front surface that 1) increases low frequency absorption over plain rigid fiberglass, and 2) reduces (intentionally) the absorption at mid and high frequencies.
Rick,
I thought Ethan answered your question about the mid/high frequency barrier as noted above. There are times when you really do want a true bass trap only and not a broadband absorber, and in those instances I think his Mondo trap design fits the bill. I have something similar that I constructed in my studio (long before Real Traps came along) and I believe it is effective, but it is hard to say since I intentionally built it in before doing any testing in the room. I also have a "poorman's" broadband corner absorber (ie. 3 rolls of R19 insualtion stacked in a corner and covered with fabric).
Anyway, I wasn't sure if your comments were based on his note or if you had missed it, so I just HAD to point it out (being the cantankerous man that I am).
Cheers,
Darryl.....
doesn't answer my question.
(You know what I mean Ethan
Hey Ethan, you know me, I meant NO implications. I only search for the truth. BTW, thanks for the insight into your manufacturing technique. I applaude you as not many manufacturers will tell you their proprietary techniques. Thanks Ethan, that tells me something new.
. OR if you had a pinhole in a wall, the only wavelengths that would propagate through this hole would be proportionate to the diameter of the hole, which is totally against what Everest says. I'm no expert, but even Everest suggests the edge effect is due to exposed edges, and the more you cut up a given square footage of material into patchs, the more edge area you expose which translates into more absorption. So, who do you believe? Anyway, I just wanted to let you know "I" agree with you.
