D
dintymoore
Guest
Here's something that took me awhile to stumble upon. Here's the song "Genius of Love":
If you click and hold where I've got the green X, and then drag to left it will select all of the clips in that horizontal row, like this:
Then if you click the arrow in the lower right hand corner:
You'll see this:
See how it says "12 Clips" in the upper left hand corner? Well, anything you do to this screen will affect all the selected clips! Happy New Year!
So you can change the text (red arrow) in the clips (I usually delete it so it looks better), the color (green arrow) of all the clips or any of the other parameters in this box. Where it says "Follow Action" is where you decide if the song will continue or what. Where it says "16" below that is the last bar in all of the clips.
When you drag a Standard Midi File to Ableton, if the clips aren't the same length it can present problems, so I make all the clips the same length in that box, plus the Groove and Signature.
Other times Ableton has magically changed some tracks in a SMF to be in 1/4 or 3/4 while all were saved on Cubase as 4/4.
So I always check each clip to make sure they are the way I want them to be.
There is no way I know of to make a tempo or time signature change within a clip in Ableton. Or program change. These appear to be a major flaws that hopefully they'll fix... maybe around 2023 when the MIDI "Star Trek" Transporters come out.
You'll see this:
So I always check each clip to make sure they are the way I want them to be.There is no way I know of to make a tempo or time signature change within a clip in Ableton. Or program change. These appear to be a major flaws that hopefully they'll fix... maybe around 2023 when the MIDI "Star Trek" Transporters come out.
