Solved Change the Tempo of a Track or Song on the Tascam DP 32 SD...
  • Thread starter Thread starter FreedomLighter
F
FreedomLighter
Hi everyone,
The song I made needs to be sped up as the Metronome was set a bit slow when I recorded the song, which is in time. It now needs to play faster.
Speeding up the Metronome has no effect on the song speed.
How can I speed up the song or track?
I'm not sure the 32 offers that option. It's not in the manual that I can see.
If you don't already have one, you could download a DAW for it's free use period and use that to alter the playback speed,
then render that to whatever media type you want (.mp3, .wav, etc..).
Comments by Phil Tipping
Hi,
I'm afraid there's no way of doing this within the machine. The only option I can think of is to transfer the track(s) to a computer (via the Export function), then use an audio editor or DAW such as Audacity to shrink the audio. You can then transfer the file back into the machine (via the Import function) if you want to do more recording/processing, or just leave it on the computer and do the mixing/processing there.
Hope this helps.
Phil.
Thank you mate, just needed one more quick opinion...
M
Replies
1
Views
505
rob aylestone
rob aylestone
Replies
1
Views
1K
PorterhouseMusic
PorterhouseMusic
TascamJimi
Replies
4
Views
2K
TascamJimi
TascamJimi
