Solved Change the Tempo of a Track or Song on the Tascam DP 32 SD...
  • Thread starter Thread starter FreedomLighter
F
FreedomLighter
Hi everyone,
The song I made needs to be sped up as the Metronome was set a bit slow when I recorded the song, which is in time. It now needs to play faster.
Speeding up the Metronome has no effect on the song speed.
How can I speed up the song or track?
Comments by Phil Tipping
Hi,
I'm afraid there's no way of doing this within the machine. The only option I can think of is to transfer the track(s) to a computer (via the Export function), then use an audio editor or DAW such as Audacity to shrink the audio. You can then transfer the file back into the machine (via the Import function) if you want to do more recording/processing, or just leave it on the computer and do the mixing/processing there.
Hope this helps.
Phil.
M
Replies
1
Views
497
rob aylestone
rob aylestone
Replies
1
Views
1K
PorterhouseMusic
PorterhouseMusic
TascamJimi
Replies
4
Views
2K
TascamJimi
TascamJimi
