B BigPapaFly New member Feb 19, 2003 #1 okay...i've given up on midi for the time being...wilo someone please tell me how to make a "rigid" midi song "swing"? Thank you.
Porter aka WookieMan Feb 19, 2003 #2 The How-To is on page 249 of the manual. The command is under Process - Quantize. The help file should give you an indication of all the settings (Strength/Swing/Window) what they do and how to set them up. Porter
moskus The Creator of Æ, Ø and Å Feb 20, 2003 #3 Ctrl+A to select all tracks. Rightclick on one clip and go Midi Effects -> Cakewalk -> Quantize. Set the swing to 100%. But the best way is IMHO, is play the song in with swing....
R roostmusic New member Feb 20, 2003 #4 to do this without changing the midi data, you could add a qunatize midi effect to every midi track in your song with the same swing rate.
