I mean, drums are not fixed pitch instruments, but that being said, as a jazzer, it is somewhat common place to tune to a fixed pitch. It will never sing out to exact measurements with the capabilities of a guitar tuner, so no matter how accurately u try to tune, it will never read out like that. With a TuneBot device it gets close to that tho. SO many tune drums in 4ths fifths, etc...
Obviously, u miswrote as u are absolutely looking to change the pitch of the drum, no? It will have a different tension on the head with the new pitch achieved and some of the dynamics will inevitably change, but to get it in the same vein of response characteristics, make sure to tube the top head to desired pitch and then make sure the ratio or tension or head tightness of the redo bottom head is similar in ratio to the top. In other words, if looking to get close, measure the top and bottom head tension compared to one another, if the top is equal to the bottom, then do that again, if the preferred reso head is looser compared to the top, try to keep the same ratio at different top head pitch. This will get you close to the same resonance and spread, but again the head tension related to the pitch change is going to have an effect, such that the sweet spot of the top and bottom head to get the desired match might vary. At higher pitch/tensions for example, the sweet spot might be more limited throughout the tuning range making my selection of pitch tuning more restricted if I want the drums to still sing the same way.
