G
gordone
Hello,
I had the same problem when I moved from an SM-58 to an AT-4033 for vocals. It picked up too much acoustic guitar! I put it through an Aphex 107 pre direct into an MD4S. I use 1 of 2 solutions. First - record the guitar first. This is preferred sonically because I can then use the AT-4033 and my small diagphram mic (A TOA K2) I usually use on my guitar to stereo mic the guitar and then go back and do the vocals with the AT-4033.
Musically, however, I like to sing and play at the same time. My solution was to put the AT-4033 closer to my mouth so that it's almost right above the guitar body. Since the AT is cardiod, it blocks out more of the guitar when it's below the mic. The downside is that I lose a bit in the vocals when the AT is close to my mouth. With some experimentation, you should be able to find a nice compromised position to place the vocal mic. Good luck!
