Celestion vs Jensen
  • Thread starter Thread starter pdadda
pdadda
pdadda
Captain Sea Boots
I recently bought a vintage Alamo amp, and I really loved the sound. My only gripe was that it had a big bulky Celestion G12K-85 16 ohm speaker in there. My amp is wired for an 8 ohm load. The speaker was so large that it was hard to swap tubes in and out. So I sold it and bought a Jensen P12R based on a local amp tech's advise. Lo and behold, I discovered I don't like the sound of speaker break-up. By the way, thus is a 15W amp. So now I am on the speaker prowl again. Did Celestion make an 8 ohm G12K-85 speaker? Or would that even sound the same as the 16 ohm version. I basically want a speaker that sounds like the old one, and if possible I want it less bulky. I also see that there is a G12K-75. I doubt my amp will breakup either of those speakers. Does that speaker sound quite similar? I assume it has a smaller magnet, and it might be the perfect fit for my cabinet.
Also, if anyone wants to buy the P12R or do a speaker trade, I am open to that. The speaker is brand new, with about 2 weeks of breaking it in.
The Jensen model you mentioned is an alnico, and the Celestion was a ceramic. The should sound different. :D
True. This new speaker has less low end as well. Much more crisp mids though. It would probably cut through the mix quite well for recording. Interestingly, when I borrowed a friend's strat and played through the amp, it sounded freaking great (I play a Tele Deluxe 72 RI).
that because strats rock and teles suck. :p (kidding)
strats are better though
Alnico is much better for clean, they literally don't want to distort. Jensen makes a Neo that's nice and I think all of $80 new. That might be up your alley.
