treidm
Spinning Wheels
On my freebie, experimental deck, that was given to me, I have been experiencing a problem.
Preface Details:
1/4", 1/4 track, 7" reels.
Manually cleaned interior & exterior,
Cleaned heads etc...
Demagnetized heads.
Using brand new Quantegy 407 1mil tape.
Recording at 7.5ips
At times, Tape will spit itself out towards you, from between the capstan & pinch wheel, when playing or recording. More often happens at beginning of reel, when take up reel is empty.
If you are deep enough into reel, it usually will operate ok.
Sometimes it will operate ok, wherever you are, even at the beginning, where it more often, is at its worst.
Oh yes, Unloaded/Loaded tape multiple times on reels, at play speed & rew/ffw speeds, to see if there was a difference.
The rew/ffw repacking actually acts up less, but not by a large margin.
(After unpacking, I always try to repack digital tapes or cassettes at play speed, thought the same could be true for reels.)
Also tried different reel combinations ie. swapping sides, flipping, changing which two reels are together. (Limited to the three plastic reels that I have, so not that many combo's, but tried anyway )
What adjustments need to be made, to correct this problem?
Preface Details:
Demagnetized heads.
Recording at 7.5ips
