Capacitor help...
  • Thread starter Thread starter peritus
Could someone post a part number or link to a supplier page for the 0.1 uf capacitors that are best for bypassing large electrolytics? Are they the same type used for power supply bypassing close to an op-amp?
There is nothing magic about 0.1uF, really it should be as large as a poly you can fit. That said, since impedances are generally in the range where 10-47uF caps are common, 0.1uF tends to be the right value for bypassing somewhere above 10kHz.
Yes, you can use the same kind of cap for power supply bypass. However, I tend to design with poly film box caps, because they are small, but when doing mods, it's nice to have longer leads for fitting on the bottom of a PCB when you are bypassing an electro with only a single set of holes available.
Anyway, the Panasonic B series poly caps are good.
These are the 0.1uF Box Bypass caps that I use quite often:
http://cgi.ebay.ca/50-ERO-1uf-250V-...3QQihZ003QQcategoryZ40113QQrdZ1QQcmdZViewItem
They are Really Cheap (50 for about $7) and are quite good quality and sound quite neutral.....
I also use these ather Non Box type 0.1uF metal film caps made by Matsutisha (Or something like that...lol) that are like $3 for 100 that have long leads that also sound quite good but the seller doesn"t have any right now.....
That seller who"s link I posted above actually sells a lot of very inexpensive parts that are of good quality so you might want to check his other auctions....
Cheers
mshilarious said:
A little is OK, but don't go crazy. You will just cost yourself money, and the higher rated caps are bigger and might not fit. Also I read something about a cap needing to see a significant % of its rating, like 30% or something, to prevent premature aging. Or something like that, I forget.
When I first read that, I thought you were nuts, since that's the exact opposite of how I've usually seen then used, but you're right---actually, you're not paranoid enough. :D
Actually, the recommended range is as high as 70-80% of their rated value. However, in a lot of consumer electronics and computer electronics, I've seen 35v parts used for filtering 9-12VDC power, which comes awfully close to that 30% figure when you take the tolerances into account. One reason for the difference is that under higher than typical temperatures, the electrolyte would break down well below the rated voltage, so 30% of rated capacity ends up being a much higher percentage of the actual capacity in those applications....
Basically, in a circuit, over time, the voltage handling capacity of electrolytics degrades (reforms) to the working voltage. The excess voltage handling provided by choosing a capacitor with excess capacity thus slowly goes away over time. After some number of years, a relatively small surge above the typical voltage can cause the capacitor to fail. The bottom line is that electrolytic capacitors are somewhat disposable and typically have a maximum life expectancy of single digit years. If you have an electrolytic that lasts more than 10 years... maybe 15... it's a fluke.
The degradation, of course, is accelerated by heat, extreme voltage spikes, etc., and I believe that the effect can be reduced by periodically ramping the capacitor up (slowly) to a higher working voltage, though in practice, this is rarely done. It might also be reduced by running the part through an extended burn-in period at the rated voltage, but I'm not certain of that.
Related readings:
http://yarchive.net/electr/electrolytic_caps.html
http://www.electronicproducts.com/Showpage.asp?Filename=itw.may2006.html
peritus said:
Be Advised: I'm a newb to the electronics world....
I've got this mini reel to reel... I want to replace some visually failed capacitors... They are polarized, axial and appear to be film capacitors...
They read 10v 1000uf...
Problem is, I want to buy them from this local store (partsexpress)... I can't seem to find one to match exactly.... Can you help me find a reasonable replacement? I'm lost!
Thanks a million!
partsexpress.com
Digikey sells the Panasonic 105C rated electrolytic caps. Be carefull to get "axial" or "Radial" lead whichever you need.
Cheers
If these are a good option, I may just buy them. With shipping to the states it'll be $13 for 50 pieces. Is that reasonable? Are these overkill for power supply bypassing close to bi-polar op-amps? I would also like to use them to bypass some large electrolytics used for coupling in some circuits.
Ops... now I see they are fairly big, 3/4" long. That won't work... :confused:
