J
JRay
Greetings,
I've been banging my head on the floor (really, try it - it hurts!) trying to get a midi file in Cakewalk Pro Audio to play using a sample loaded into Gigasampler LE. My sound card is an Echo Darla24, which is 2-in 8-out, multi-client and GSIF compatible (I do have DirectSound disabled). I can play samples in Giga and record into Cakewalk, but I can't get Cakewalk to trigger Giga. I did select the Endless Wave as output in Cakewalk, but how do I set up Giga? If anyone has gotten this to work, could you post specific settings for both Cakewalk and Gigasampler? I'm sure this has to work without the Hubis midi workaround thing, which I tried and had to remove because it messed up everything. My PC is running Win98 and I use an outboard mixing board (Mackie 1202VLZ). If some kind soul could enlighten me I then I could rest easy again knowing that I'm not a complete hack - - - -
