R
Robus
Trace Elliot Velocette 1x10 15 watt combo
Here's another of my small amps, a Trace Elliot Velocette, recorded this morning to replace last night's DI parts above (previous post).
This is a 15 watt, true Class A amp with a pair of EL84s and a Celestion Vintage 10 speaker. It can cop a Vox-like tone. It thrives on volume. At the very top of the volume dial, 7-10, the distortion become smooth, compressed, bright but not pointy. It works particularly well with a single coil guitar like a Tele or Strat. I use a lot of right hand finger action in my lead parts. The amp's natural compression smooths out the volume spikes from finger plucks. It does one of the best classic Tele sounds of any amp I've owned.
I bought it new about 2000, around the time Trace Elliot was ending production. I played it for about a year until the output transformer died. There was a manufacturing flaw that caused these transformers to burn out. Trace Elliot sent me an upgraded transformer--and a second one as a spare.
Never had a problem since. After TE discontinued the amp, Gibson picked it up and sold a nearly identical amp as the Goldtone. If you run across a Velocette, I'd highly recommend it provided the transformer has been upgraded (likely if the amp has been in continuous use).
It is surprisingly loud. Needless to say, I was playing in a room around the corner to the right, with two closed doors between me and the amp, monitoring on my studio monitors at a comfortable level.
About as simple as it gets: A volume knob, a tone knob, a bright switch (noisy), and an on/off/standby switch. There's also a speaker out.
Here's the clip: It's a Fender Telecaster, bridge pickup. Amp volume at three 'o clock, tone at noon, bright switch off, SM57 on axis, just outside the dust cap and about 1/2 inch from the grill cloth. I recorded delay from a TC Electronics Flashback into the front end. The clip contains the rhythm guitar part, followed by the lead, followed by the song mix with both parts, rhythm left, lead right.
Never had a problem since. After TE discontinued the amp, Gibson picked it up and sold a nearly identical amp as the Goldtone. If you run across a Velocette, I'd highly recommend it provided the transformer has been upgraded (likely if the amp has been in continuous use).It is surprisingly loud. Needless to say, I was playing in a room around the corner to the right, with two closed doors between me and the amp, monitoring on my studio monitors at a comfortable level.
