Can I use Tape Out/In as Effects Send/Return?
  • Thread starter Thread starter canakas
C
canakas
Hello all,
Can I use Tape Out (1 kOhm) in mono to feed an effects chain (input impedance > 2 MOhms), and return the signal (output impedance unknown) to the Tape In (> 10 kOhms) ?
I am specifically thinking about using this solution with a Mackie 402 or similar tiny mixer and my EHX SMMH.
Or if you know of a -tiny- mixer with effects send, please let me know!
Thanks for your replies.
cancancancancan
The output is after the input so it would feed back horribly if you did that.
Hi bouldersoundguy,
Thanks for your reply... you are indeed correct... I realize this now when looking at the block diagram.
Mackie tech support just chimed in saying that the tape outs are not meant for this use, and suggests that a more feasible workaround would be to mix inputs in the 402 and then run the Main Out(s) into the effects chain and then connect the effects chain output to the PA. The wetness of the sound would then have to be controlled on the pedals themselves.
This is a possible solution for me, if my distaste for taking 30x30 cm of mixer to the stage with me, does not subside... =P
