can i use my rega trio r amplifier with yamaha ns10s?
  • Thread starter Thread starter panax_27
P
panax_27
Member
its a rega brio R integrated amplifier 115 volts.
wondering if its compatible or if its a good fit for yamaha ns10s.
thank you
thank you
I hope you mean "watts" because you don't want to hook spakers up to anything spitting volts.
It's an amp. I'd run NS10s or other speaker like them from any amp really. Currently, the 5" monitors in my video studio are being powered from a 2400W 19" rackmount PA amp - simply because it was sitting on the bench. If you have bought the NS10 speakers, you now know what they sound like and all that matters is if you like the sound.
The Brio Trio R is 50W/Ch which should be sufficient to drive most speakers. Unless you are really monitoring at a very loud level, you'll probably only use 10 watts or so. I have a 50W/Ch Bryston amp driving an old pair of IMF speakers which are not very efficient, and for the clipping LEDs to fire, it's incredibly loud, and pumping out heavy bass.
BTW the Rega is designed to run on either 115 or 230V, so you can run either in the US or UK, just need the appropriate power cord, which should be supplied from the dealer.
