E
		earworm
ok, i'm going to help a band with their live performances,
they got all their cheap gear and want me to make them better
so they got this "sound bank sound" powered mixer,
doesn't sound good at all but hell, it works,
its got two main outputs of
250W @ 4 ohm (on each channel) , both are only Speakon outs,
1) i'd like to put a limiter or EQ between the main outs and speakers,
but isn't it dangerous to connect an EQ to a 4 ohm output?
can it harm the equipment?
and how would i do that, take a short "speakon-to-jack"cable from the mixer to the eq,
and then connect the eq out to the speakers,
i'll just find me some short speakon-to-jack cables if this won't harm any "line level equipment"
and next; i can't find info or a manual of that mixer, since its infamous junk,
it doesn't have a master insert which is too bad, but it does seem to have
2) MASTER AUX stereo send and return, seems like this is seperate from the AUX1 and AUX2 (send+return)
why would you wanna put a reverb or something on your main mix,
might this just be a master INSERT instead of master LOOP (like its called)
bad news is that i can't test anything, got a live PA on saturday and then i'll have to see that i can handle this stuff or not, its easy to use but it doesn't sound good, so its gonna take some time and effort to "fix it"
thanks in advance for any advice
3) additional question; is speakon Balanced?
i got some NL2fc cables here...
4) so we got two Montarbo speakers,
http://www.montarbo.it/pdf/W400P_manual.pdf (this is the new version of the speakers)
speakon connection to the powered mixer, but these two montarbo's have "PARALLEL INPUTS",
the band has on one of those parallel inputs another speaker connected, in serie,
so now they have 2 Montarbo's for FOH,
and two 'bird electronics' speakers for monitoring, and these birds are connected "via parallel inputs" to the Montarbo's,
now whats up with the OHM stuff.... if i'm correct the montarbo's are 8 ohm, the mixer outs are 4 ohm, .... and i don't know how much the Birds speakers aer... are we loosing signal here because of impedance issues?
4ohm mixer out to 8 ohm speaker in (is this OK??)
and then those 8-ohm-speakers have to split the signal with two other speakers, are those extra speakers supposed to be 4 ohm then?
something doesn't sound logical to me..;what do you think?
							 Have fun!
 Have fun!
