I just bought a 1402VLZ mixer to replace an absolute piece of garbage Behringer 1604. The problem that I have which is actually a continuation of a problem that I had with the Behringer is that The way I have set up my DAW, my monitor levels are always considerably higher than my recording levels. I cannot figure out why.
My setup
P-3 850 puter
M-audio delta 66
Alesis M-1 Active monitors
Mackie 1402VLZ
AT 4033A mic
POD line 6
Cubase 5/32
I have the ins 1/2 of the delta card going to the control room out's on the back of the mixer.
The out 1/2 of the delta going to the line L/R channel 11-12 of the mixer.
My monitors are connected via balanced XLR to the main L/R of the mixer
My C-R source on the mixer is set to "Main Mix"
Here are the symptoms--
Say i plug the mic into channel 1 of the mixer with phantom power on. I have to punch the trim up to around -30 to -40db for a good hot signal. I record into cubase. When i stop recording & playback the wav file, the volume is considerably lower than my monitor volume, + the wav file does not represent the "hot" signal that I set pre-recording. It seems to have recorded at a much lower level. Does this make sense?
Any help would be very much appreciated.
Thanks all.
My setup
P-3 850 puter
M-audio delta 66
Mackie 1402VLZ
AT 4033A mic
POD line 6
Cubase 5/32
Thanks all.
