That is better! Thanks guys.
Neoplitan - 16 bit Black Face TypeI ADAT's.
Unheald - 20 bit ADAT XT.
Secret Heart - 16 bit ADAT's again.
Oops, was tired last night and didn't post a 24 bit recording. Oh well.
It actually helps the cause.
You guys certainly got the sample rate one's correct.
So now, tell me guys, which is more important? Increased bit depth or higher sampling rates?
THAT is not an easy answer.
Even through Unheald was recorded at a higher bit depth than the other two, it was mixed on a digital console. The other two were on a analog console.
Worm was mixed on a digital console, Toothache was mixed in Sonar.
Where am I going with this? Hell, I am not even sure, except to say that it is usually more obvious to the average Joe the difference in sample rates than bit depth! I have "secretly" tested this on clients time and time again. I also trust female ears a LOT when it comes to frequency response, and women ALWAYS hear the difference in sampling rate. Lower rates usually get the response that the audio sounds more "harsh".
Worm was the only 24 bit recording of the bunch (true 24 bit..meaning, Toothache was 24 bit, but used 16 bit 44.1 drum samples, and
a JStation for the guitar/bass using the S/PDIF output...it says 24 bit converters, but I have reasons to believe that the JStation isn't more than 20 bit at best!)
Worm has the lowest perceived resolution of the whole lot! Why? It went through MANY more steps of digital hocus pocus. Sonar editing. Sound replacing. Digital mixing. Etc....
Neopolitan to my ears has the most resolution of the lot. That was 16 bit ADAT's to a Soundcraft Ghost using Behringer Composers and Alesis 3630's for dynamics. I have another song from that CD that is a more delicate "jazz" tune on it where you can hear subtle brush's on the drums and it explodes to a huge chorus part. MAN!!! Is it a dynamic song. Preserved VERY well on a 16 bit recording.
I hear all this talk about how 24 bit has a much lower "noise floor". Cool. In theory, it certainly does! But you know, check the noise floor of your average preamp. Times that by how many tracks you have running at once. Oops, there goes your nice low noise floor!
Okay, everybody flunked the bit depth test. I am going to see what I can do about getting a better sampling rate test going here. It is my opinion that I benefit FAR more from increased sampling rates than I do from increased bit depth. Time and time again, increased sampling rates are far more obvious to me and everybody else than increased bit depth, yet, the average advice posted on BBS's suggests the opposit! A lot of techno mumbo jumbo that is only half right get's thrown around about increased bit depth and everybody discounts increased increased sampling rate in a hurry, yet, time and time again, increased sampling rates seem to be a more obvious improvement to the audio than increased bit depth does!
Okay guys, don't get going on this whole "well, 24 bit's is better if you are going to apply DSP" thing. I agree wholly with that. But I tell you, the difference is NOT going to be as obvious as the difference between 44.1 and 48, or for that matter 96KHz sampling rates!!!
I will see what I can do to make a better sampling rate test here and see how you all fair. I doubt many are going to flunk this one like you all did the bit depth test.
Ed
