Dolemite
I'm pretty new to the recording scene but I can't help but notice the constant reoccurance of these two words: "tube" and "warm". It seems that if a preamp or other piece of equipment has a "tube" in it, it then must be "warm." Also, it seems that any large diaphram condensor mic is good, it must be "warm."
Everything that is warm is good by default.
OK, I know it's soooo much more complicated than that but if I had no knowledge of recording and was not technically-minded and started reading these forums, these are the conclusions that I would draw. Basically, I think there is a huge amount of hype surrounding these terms that is created by manufacterers and propagated by the misinformed/inexperienced. For example, ART is selling thousands upon thousands of their Tube MP's despite the fact that many people with extensive technical backgrounds and years of recording experience have determined that the tube itself plays a minor role in the Tube MP's amplification circuit and it does not sound particularly "warm." People buy it knowing there's a magical "tube" inside and it will make their recordings "warm." They use it and are convinced that their vocals/bass/synth/whatever sounds "warm" through the Tube MP, but what do they have to compare it to and do they even know what "warm" is? Somehow I doubt it. I tend to think that a similar phenomenon occurs with microphones. People buy a Rode NT1 as their first LD condensor, they then recommended it to others, saying it sounds "warm." Do they know whether it's "warm" compared to other LD condensors? I'm not sure they do. I know I wouldn't.
I know there are a lot of really knowledgeable and experienced people here who could probably write a book about this topic. I would really appreciate an explanation of "warmth" for the benefit of myself and my fellow newbies. I would like to know:
1. What "warmth" is
2. What it sounds like
3. Why it is so desirable
4. What results in a "warm" sound from a microphone
5. What results in a "warm" sound in other gear
6. How can "warmth" be added to a recorded track
Also, if you're new to recording like myself, what clued you in that you were getting a "warm" sound? Was it an obvious audible difference or were you convinced less by your ears and more by marketing hype?
All insights are appreciated.
1. What "warmth" is
