burning--lost
  • Thread starter Thread starter atorifan
A
atorifan
had a cd burner for 2 months, worked fine. it is an iomega zipcd. well last week it refused to use easy cd creator successfully. it would stop after the first track. i've wasted about 11 cds tryin to get it to work. btw i am using 700mb cds, which worked fine, the first two or three. so, i used the wizard and that seemed to work for at least one cd. now it no longer works at all. i have defragged, changed write to 1x, still does not work. i even uninstalled drive and software, and reinstalled. it still stops after the first track. either i need recommendations for new software, or there's something else wrong here.. any advice/solutions. i did run the tests and my system worked fine. i have been burning from hard drive in .wav format. thanks
While I try & figure out what's goin on with your CD burner, here's some very good advice for you...Use only Re-Writable CD's (CD-RW)
unitl your problem is resolved...You can use these over & over until you fix your problem.
Sounds like dead or dying hardware to me, unless you just did some system software stuff right before it happened. Dougie...25 points for a great money-saving idea!!!
