jimistone
long standing member
What effect does burn speed have on finished CD
The slowest speed possible will always be your best bet!!!
Slower speed will not skip in cd players where as fast speed will skip or just plain not work at all in cd players.
That's some immeasurably bad information.
Most studies (my own included, which were pretty substantial) find a "sweet spot" of sorts at around 25-33% of a drive's rated speed. Which for the most part, is how it's always been from the advent of CD burners (1x was popular on 4x drives -- 25% of the rated speed). The results were pretty solid along over about dozen drives (from $50 POS drives to $400 "nice" drives) over a wide range of media (Chinese discs suck, Japanese discs rock, Taiyo Yuden being the king of the hill for QC and consistency, as one would imagine).
12-16x on a 52x drive is perfectly fine. SLOWER speeds tend to get significantly HIGHER block error rates (as do freakishly high speeds).
If high-speed discs skip, there's a problem with the burner.
This is what I've found to be true!I can see what moresound was tring to say but did not go into detail as you did.jimistone said that he had found the same problem after burning at fast speeds.you just have to find the speed that fits your drive.
And they're terrible coasters, instead of a ring they leave a spot...Fewer coasters.
Back in the early days, older drives could only play discs burned at a speed closer to their specifications. Back when 4x was considered a high speed drive. So you pretty much got used to burning discs at the slowest possible speed, for compatibility sake. Those drives are still out there. They're just not as common now. And if you try to run your drives that slow these days, they wont do a good burn at all. I tend to just let my drive run at a default speed. Fewer coasters. There probably is a sweet spot. And it's probably not the fastest speed. And probably not the slowest either.
Exactly like that...Never heard this issue, I n som, k will be th something like that
was pr ly enou h o
