F
FolkDog
I used to build my systems by hand back in the days of Apple IIs and 386s. Then I got busy, so I've let Dell build them for the last decade. My old PC is getting dated now and it needs more memory, HD space and a better processor -- but I've also spent a bunch of money upgrading the CD Burner, Video Card, keyboard, mouse & Monitor. So, rather than buying a whole new Dell system with a bunch of parts I'd just swap out for my own, I'm thinking maybe I'll build a box again.
Done a little research and come up with the following part list on NewEgg. Comes to about $1300. My question to you, all knowing Homerecording.com BBSers is "What would you change?" Also, does anyone know if this fan and case are QUIET?!
It needs to be PC, because I'm stealing all the stuff I mentioned above out of my current system. This is a recording hobbyist system for a geek whose going to enjoy building the damn thing as much as using it.
My current soundcard is an Echo MIA. I'm also considering upgrading that while I have the checkbook open - but my max is $1500 so I'd have to cut somewhere else.
Parts list follows. Thanks in advance for your advice!!
Thermaltake Blue Highest Xaser III Super Tower Chassis without Power Supply, Model "V1000D" -RETAIL
Specifications:
Case Type: Xaser III Super Tower
Color: Blue
Material: Chassis:1.0mm SECC Japan Steel, Front Panel:Aluminum
Drive Bays: 5.25'' x4,3.5''(External) x2, 3.5''(Internal) x6
Expansion Slots: 7
Front Ports: USB2.0 x2,IEEE1394 x1,Mic x1,Speaker x1
Power Supply: N/A
Cooling System: 80mm Silent Fan Front x2,Rear x2,Side x2,Top x1
Motherboard Compatibility: Standard ATX,Micro ATX,Extend ATX
Dimensions: 20.9''x8.1''x20.5'' (HxWxD)
Special Features: °C / °F display switch, 4 channel adjustable fan speed knob,Two way lock in front panel more info-> N82E16811133106 $129.00 $129.00
ASUS "P4C800 DELUXE" i875P Chipset Motherboard for Intel Socket 478 CPU -RETAIL
Specifications:
Supported CPU: Socket 478 Pentium 4(HT)/Celeron Processors
Chipset: Intel 875P + ICH5
FSB: 800/533/400MHz
RAM: 4x DIMM support Dual Channel DDR400/333/266 Max 4GB
IDE: 2x UltraDMA 100, 1x UltraDMA 133(from Promise 20378) up to 6 Devices
Slots: 1x AGP Pro/8X, 5x PCI, 1x Wi-Fi
Ports: 2xPS2,1xCOM,1xLPT,8xUSB2.0(Rear 4),1xLAN,2x1394(Rear 1),SPDIF Out,Audio Ports
Onboard Audio: AD1985 6-Channel Codec
Onboard LAN: 3COM 3C940 GbE
Onboard SATA/RAID: Promise 20378, 2x SATA, RAID 0/1/0+1/Multiple RAID; ICH5, 2xSATA
Onboard 1394: VIA 1394 Controller
Form Factor: ATX more info-> N82E16813131449 $163.00 $163.00
Thermaltake W0010 Silent Purepower 480W with Black housing - Xaser Edition ATX 2-Fan Power Supply
Specifications:
Type: ATX
Maximum Power: 480W
PFC: Active
Power Good Signal: 100-500ms
Hold-up Time: >16ms at Full Load
Efficiency: >65%
Over Voltage Protection: +5V trip point<+6.8V;+3.3V trip point<+4.5V;+12V trip point<+15.6V
Overload Protection: Not specified
Input Voltage: 100 - 240 Vrms
Input Frequency Range: 47-63 Hz
Input Current: 8A
Output: +3.3V@30A;+5V@40A;-5V@0.3A;+12V@18A;-12V@0.8A;+5VSB@2A
MTBF: Not specified
Approvals: Not specified more info-> N82E16817153009 $65.00 $65.00
Intel Pentium 4/ 3.2C GHz 800MHz FSB, 512K Cache, Hyper Threading Technology - Retail
Specifications:
Model: Intel Pentium 4 w/ Hyper Threading
Core: Northwood
Operating Frequency: 3.2GHz
FSB: 800MHz
Cache: L1/12K+8K; L2/512K
Voltage: 1.55V
Process: 0.13Micron
Socket: Socket 478
Multimedia Instruction: MMX, SSE, SSE2
Warranty: 3-year MFG
Packaging: Retail box (with Heatsink and Fan) more info-> N82E16819116164 $277.00 $277.00
Crucial 184 Pin 512MB DDR PC-3200 8T - OEM
Specifications:
Manufacturer: Crucial
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 3
Support Voltage: 2.6V
Bandwidth: 3.2GB/s
Organization: 64M x 64 -Bit
Warranty: Lifetime more info-> N82E16820146541 $93.00 x4 $372.00
Western Digital 120GB 7200RPM SATA Hard Drive, Model WD1200JD, OEM Drive Only
Specifications:
Capacity: 120GB
Average Seek Time: 8.9 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: Serial ATA
Features: Not specified
Manufacturer Warranty: 3 years
Packaging: OEM Drive Only more info-> N82E16822144151 $100.00 $100.00
Western Digital Raptor 74GB 10,000RPM SATA Hard Drive, Model WD740GD, OEM Drive Only
Specifications:
Capacity: 74GB
Average Seek Time: 4.5 ms
Buffer: 8MB
Rotational Speed: 10000 RPM
Features: High Performance SATA Interface
Manufacturer Warranty: 5 years
Specifications:
Color: Blue
Expansion Slots: 7
Power Supply: N/A
Specifications:
FSB: 800/533/400MHz
Specifications:
Type: ATX
Maximum Power: 480W
PFC: Active
Efficiency: >65%
Input Current: 8A
MTBF: Not specified
Specifications:
Core: Northwood
FSB: 800MHz
Voltage: 1.55V
Process: 0.13Micron
Socket: Socket 478
Specifications:
Cas Latency: 3
Bandwidth: 3.2GB/s
Specifications:
Capacity: 120GB
Buffer: 8MB
Specifications:
Capacity: 74GB
Buffer: 8MB
