I got the 4 new condition Switchcraft 96pt bays for $20 total. [duck]
Wait...just looked at the pictures again and they are 144pt...basically 48 3-jack sets, one normalled pair and one non-normalled (I think)
They look like this:
Silliest part is I don't need them but for $20??
I have all the ADC bays I need and more to build up the patchfield on my MCI console so these are just surplus. I'll put them on eBay and see what I get.
Foil shield provides for 100% coverage. Braided shield typically doesn't get much better than about 90%.
Be careful with the coaxial stuff because some of that stuff is designed for 75ohm video and you don't want to use it on audio.
The other thing about coax that I don't really like is that the center conductor is solid core. Electrons don't travel
through a metal conductor, they travel on the surface, so stranded cable is better because it provides more surface area.
Shielding is the same for balanced vs. unbalanced, so what's good for unbalanced is good for balanced and vice-versa. What's MORE important is how the shield is tied to the system at each end and how each device deals with audio grounding...can of worms and I'm putting my can opener away unless you have questions or more importantly problems to resolve.
Cable that's good for high impedance is good for low impedance and vice-versa. You want good quality stranded conductors, good shielding...one factor to look at is the capacitance of the cable but pretty much any decent cable is going to be acceptable in that area and the Gepco cable is no exception. I just keep pushing the Gepco stuff because it is very reasonably priced and though it doesn't have the same name as a couple snobbish brands it is perfectly good cable...even great cable and the price is right.
It doesn't matter what kind of connector is terminating the cable...the same demands apply to the cable regardless of the ends. 24AWG is fine, 22AWG is better. Most of my multi-channel snake cable is the Gepco GepFlex stuff which is 24AWG and I'm not worried because all of my snakes are 16' or less. I have some longer snakes for remote work that have 22AWG conductors but inside the sound room its mostly 24AWG. I'm going with 22AWG with the MCI harness because that's what MCI used and what the MCI guys say I should use. Fortunately the Gepco stuff is priced well and comes in all the colors that MCI originally spec'ed for their harness so I'll be able to recreate it visually and according to the original cable spec.
