H
Hiwatt Bob
ok,
i have been using the pre's on my behringer for the last couple years, and i wanted to get a mic pre that warmed up the sound a bit, coloration would be a good thing.
so i went out and bought the brick (figuring on some tube warmth) and a Joemeek VC6Q.
today i ran some comparisons using a strat direct in. i recorded direct into my echo layla. all EQ's were flat (except i did boost the treble a bit on the joemeek). i was mystified by the results. the behringer was the warmest of the three, by far. in fact, the brick and the joemeek sounded remarkable similar. truth be told, there was more high end clarity on those two--but i guess i was looking for a pre that would warm/fatten things up. these two seem much more crisp, which might be good for certain things--but i was looking for warmth.
another thing that mystified me was the Bricks inability to clip. i tried to get a signal that hovered around 0 db, with peaks that would go into the red but would not clip. i had to set the meek very conservatively, lots of gain on hand here. and even the behringer was set conservatively, with the trim around 30 db and the fader dimed to +10 db. I had to dime the Brick to get it to hover around 0 db, and no matter how hard i played--i couldn't get it to clip. it says it's +55 db when maxed. i actually have 2 bricks here right now and i tried the other one, same results. does this seem right??
tonight i'm staying in so i plan on running more tests with mics, maybe that's where the differences will show up. yesterday i briefly ran a test with an SM57 and the Joemeek was definitely warmer than the Behringer. but i need to test the Brick with some mics. i can update this later.
Can anyone explain the results i got?? i monitored on headphones as well as speakers and the results didn't change--so it's not that.
thanks guys.
thanks guys.
