Thank you for your kind words.
Recording brass the concern is if too close you lose the balance of the group as a whole, yet too far everything gets washed out.
The setup for this concert was as follows:
Percussion sounds on left behind the brass
Drum set on right behind the brass
Brass in two groups centered to the conductor in an upside down U. An outer group and an inner group
I used ORTF about 15 ft up and 20 feet back from the conductor
The mic setup was actually in the center aisle of the first row. I was concerned about it being knocked over, because it was a very busy intersection
So I used my Studio Projects C1's, just in case they did come tumbling down. I ran them into
my Mackie Onyx 1640.
The performing area extended further than normal to the audience because they had an extension to the stage for the conductor to stand on. This took up the whole front section that you see in the picture being empty. That is why the mic setup was so close to the audience.
Thank you once again for listening.
Take Care,
Gene
