Boss 532 bouncing tracks
  • Thread starter Thread starter j0ffan
J
j0ffan
:confused:
Just used my buddy's BOSS BR532 to record a song across the four tracks, and now want to combine them all down to a single track so I can cut a CD from it.
The manual is useless for this, so can any BR532 users out there be a star and give me the idiot's guide to mixing down these 4 tracks to just one?!
Many thanks
I haven't used mine in quite a while, but I'll try and help. I know you hit bounce, and it will have you select the track(s) to bounce to. Make sure you have the 4 tracks you want to bounce selected first. Also, make sure you want to bounce to mono. Is it 4 parts, to be one mono track? (a single vocal, or guitar...). you will need to push the bounce button a couple of times, as stereo is selected first. Then, select the track you want to bounce to. Have your volumes set first, while just doing a playback. You can also set panning, and any effects. Then you press the record button, and when it's lit, press play. Then just hit stop, when done. Should work fine.
Ed
You are a star. My buddy's just arrived, so between the two of us, your advice, and plenty of guiness we should crack it
Cheers
