electricabanana
Hey
I am using a firebox into macbook pro. the new macbook pros cannot start the firebox with bus power only...once it gets going from the AC adapter, the bus power will keep it going, but cant boot it up. a huge piss off for portable/field recording. anyways, if anyone else has this problem....
I HAVE A SOLUTION!!!!
you need to buy two 9V batteries, and two 9v battery connectors (a little thing with some ports to recieve the battery and two cords), and a tip connector that fits your unit. with the batteries it only set me back $15
wire the two battery connectors in series (positive to positive, neg to neg) and connect the remaining cords to the tip connector. voila!
i put it all together without solder, but i am a genius, and you mere mortals may prefer a sturdier soldered version, but thats the idea.
email jolanbailey@shaw.ca if you need any clarification.
