boogie triple rec fx loop
  • Thread starter Thread starter jrhoden
jrhoden
jrhoden
...And Justice For All
need help with boogie triple rec fx loop
i really need some help guys
can i PLEASE get some help with the efx loop for my boogie triple rec...
all im getting is a hum
i hook up the send and return properly ...what do i set the knobs in back to?...i know its not loop bypass but other than that im not sure
setting it to a channel locks in that channel?...im just fukn lost and pretty pissed off at the moment....
any help would truely be appreciated
thanks
Hey there
On the FX loop
From the jack marked send... hook a audio (guitar) cable from here to the input of your device.
From the output of your device hook an audio cable to the return of the amp.
On the knobs... set the send and mix levels to about 12 o clock to start.
make sure your selecter switch is in the FS position.
That should be all there is to it.
if you still get nothing but hum.... then either your outboard device has a problem, or the amp has a problem. to test if the amp is ok, run a guitar cable from the fx input to the fx return, if no hum, then the amp is fine.
i can get it to work but theres still a hum in it running a cable from send to return
when i plug it all up it workd but it gets a hum to it as well as some crackling - sounds like theres a short in it
time to take it to a shop to get looked at...
thanks for the help
thanks for the help
I had an issue recently on my FX loop where there was crossover distortion on the FX loop only. Tube issue. Take it to a tech and they can figure it out.
yeah
the only time it hums is when i mess with the fx loop - im gonna take it in and have a pro look at it
thanks
