Blue yeti monitoring issue
  • Thread starter Thread starter Toushirou1989
T
Toushirou1989
I am having issue with hearing the monitoring on my blue yeti. It has been working for a few months in till yesterday. I know its something to do with windows 10 as if I plug it in to my laptop also windows 10, It will work fine. I have tryed uninstalling blue yeti from the device manger witch did not fix the issue. I don't know where to go from here and need a little help with fixing this issue other then that, the mic work fine for recording.
Assuming you mean headphones plugged into the Yeti monitoring(?)
- Is the Playback/Output device setup for Win10 and your DAW as shown on this link.... Blue Microphones | Yeti ? All-In-One Professional Recording System for Vocals (shows up to Win8.1, but Win10 should be similar)
- What DAW software are you using?
thanks for the reply. yes its setup as the defualt for audio and recording. i ues obs as i ues the mic for broadcasting on twitch. i have not touched any setting from the day i had started using it taking about 4 months now.
Blue have released a new driver for Windows 10 which you can get here: Blue Microphones | Yeti Pro - The Ultimate Professional USB Microphone w/ Built-In XLR Output If you haven't already, it might be worth the download.
Windows 10 has a nasty habit of messing with your audio settings and not putting them back so a visit to the Windows audio control to see what's set as the default record and playback devices is probably in order.
i have check that i do not have a yeti pro so it will not work with my mic i just have there yeti mic the reugler one. or i would give that driver a try. i have sent an email to them about this issue. was just see if any one here has had this issue and know of a way to fix it.
