An amp that age needs every tube replaced. Its not hard at all, do a little reading and you can do it yourself. Otherwise, have someone do it. Your two power tubes will need to be matched for proper operation. I would say buy a pair of Mesa. You can tap on the tubes with a pencil with the volume turned up and you will hear sound through your speakers from a bad tube, especially a bad preamp tube. A shorted one will look like it has lightning (which it is) or fire inside it, and those need replaced immediatly, and will usually blow a fuse and/or burn your house down.
They are socketed, just wiggle em out, wiggle the new ones in.
The preamp tubes dont have to be in any order or matched, but always crank the amp up on dirty channel when you put em in and listen. Then mix em around. Listen. Mix em around again. Listen. THe 1st tube in your path needs to be the quietest one since any noise it creates will be amplified by the others many many times. You can ususally tell which one it is once is the quietest once you go through them. This is something most techs dont even do and MIGHT be worth the 5 minutes it takes to do it. Make sure you turn the amp back off each time.
And last on my list, always always always make sure you give it at least a one minute warm up before going out of standby mode. Its there for a very good reason. Your tubes will last three times as long if you follow this simple rule, live by it religiously. Slipping once and turning it on within 5-10 seonds, before they are completely heated, ruins every other opportunity to do so.
Bust the old ones outside on the concrete cause it makes a cool sound when the vacuum is released.
Record it as an effect for your next album.
Peace.
