			FattMusiek
I am planning my upcoming recording session of pretty fast punk band. I am pretty bent on recording this band all at once instead of step recording due to efficiency and the fact that time is money. The room in which I'll be recording is rectangular. The dimensions are approximately 8 1/2 ft x 13 ft x 14 ft. The room is treated with a decent amount of Auralex foam, covering a good amount of the walls. There's also Auralex foam bass traps on two of corners. (There are bass traps on only two of the corners because remaining two are next to a door and plexiglass. There are a few traps leftover if needed). The floor is made of wood. In this tracking room there is still an apparent standing wave issue; there was once a lot more foam up and the room sounded lifeless in a bad way. The control room is even smaller (treated similarly with Auralex foam), but it's fitted with a Panasonic Ramsa (16 input) mixing console that sounds damn good to me and offers a lot of flexibility. The facility is located in a pretty big barn, but only these two rooms are set up for recording.
Now that you have an idea of the place, my question is should I embrace the bleed and record all rhythm (drums, bass, and guitar) in the small tracking room or do my best to isolate each instrument?
My approach to the embracing bleed scenario is:
-Drums set up near the back wall
-Bass amp miked somewhat close to drums (further away may lead to phase issues), at a low volume and going into a makeshift bass trap to absorb the sound waves
-Guitar in the same room?
In the isolating the instruments option, I have thought of doing this:
-Drums in the tracking room
-Bass direct in or outside the tracking room (cement floor and thin wood walls)
-Guitar either in the control room (kills my ability to monitor at all) or out in the main area of the barn. I've also considered running a long cable up the stairs and into a very small bathroom, but I'm no so sure about that
Any insight to these approaches is welcome. I hope to hear some good stuff...
Thanks
Thanks
