Bit Depth?
  • Thread starter Thread starter chamelious
C
chamelious
www.thesunexplodes.com
In the project settings summary in the top right of Reaper, i can see that it says 44.1 and 32 bit.
I've got a Delta 44 running with ASIO, and i cant find anywhere in Reaper or the Delta 44's control panel that says anything about bit depth?
Does anyone know where i can change this? I have some drum tracks coming in at 24 bit...
Thats the bit depth reported by your driver. Most driver writers dont bother to make that number line up with the actual bit depth, but as long as it is the same or higher than your project bit depth, its fine.
Here is where you set the bit depth that matters:
Thanks very much for you very quick response. I've seen you around here and had hoped you'd be around tbh! Thanks again.
