M160:
Features
Compact and rugged design
Unique double ribbon microphone transducer
Hypercardioid polar pattern
Extended frequency response
Excellent transparency and transient response
Warm and natural sound
Applications
• Instrumental miking such as saxophone
• Miking of drums (toms, hi-hat)
• MS-stereophony with M 130
beyerdynamic is one of few microphone manufacturers world-wide that still produce ribbon microphones. A classic one is the M 160, a dynamic double ribbon microphone.
Featuring a hypercardioid polar pattern with a noise attenuation of 25 dB at 110°, the M 160 is an outstanding microphone which is very effective for all types of remote and in-studio voice reproduction. In the recording studio, the M 160 is recommended for miking string instruments such as violins, violas, cellos and for pianos, saxophones as well as for hi-hat, and toms. The non-glare black surface of the M 160 and its small dimension allow the unobtrusive use in TV or film studios. In conjunction with the M 130 dynamic double ribbon microphone the M 160 is ideal for stereo recordings in MS technique.
Technical Specifications
Transducer type Dynamic
Operating principle Pressure gradient
Frequency response (distant miking) 40 - 18,000 Hz
Polar pattern Hypercardioid
Side attenuation > 25 dB at 110°
Open circuit voltage at 1 kHz (0dB = 1V/Pa) 1.0 mV/Pa ≡ -60 dBV
Nominal impedance 200 Ω
Load impedance ≥ 1000 Ω
Diaphragm Pure aluminium
Case/finish Brass
Connector 3-pin XLR male
Length 156 mm
Shaft diameter 23 mm
Head diameter 38 mm
Weight without cable 156 g
http://www.beyerdynamic.com/com/product/index_s.php3?find=M160&Submit.x=7&Submit.y=3
M260:
Features
Rugged metal casing
Ribbon transducer performance in a rugged, versatile configuration
Extremely high gain before feedback
Fast, transient response
Wide, flat frequency response
Applications
• Vocals
• Speech
The M 260 is used for vocals and miking instruments at broadcast, recording and film studios. Its flat frequency response and natural, warm "ribbon" sonic profile make it a highly effective element of the digital recording process. The hypercardioid polar pattern provides an extremely high gain before feedback and elimination of lateral noise (maximum at 115°). The M 260 is equipped with a built-in high pass filter which compensates the close miking effect, when the mic is applied very close to an instrument. The microphone also features a high insensitivity towards magnetic stray fields and extreme temperatures. The rugged grille protects the microphone system against accidental hits and kicks.
Side attenuation > 20 dB at 115°
Open circuit voltage at 1 kHz (0dB = 1V/Pa) 1.2 mV/Pa ≡ -58 dBV
Case/finish Brass
Length 163 mm
Shaft diameter 24 mm
Head diameter 43,5 mm
Weight without cable approx. 230 g
http://www.beyerdynamic.com/com/product/index_s.php3?find=M260&Submit.x=11&Submit.y=1
It's all on
Have a nice day.
