Better Drum OH/Vocal Mic?
  • Thread starter Thread starter thecongo
T
thecongo
hey there!
im trying to decide on 2 mics that will double as drum overheads and vocal mics. Since my budget is limited right now, I'm going to wait to buy some MXL603s for the overheads, but right now I'm going buy 2 of the same type and use them. Right now I'm torn between the PPA LD-1, I like the specs and the graphs are really good, and I like the way it sounds with vocals but I'm unsure about it for use as an overhead. Or the Studio Projects B-1, I've heard great things about them, but I still have little knowledge about them. Any opinions would be greatly appreciated! Thanks!
I would say 2 mxl 2003's. But that will set you back 300 bucks. I don't know if that is in your budget. From all thats said around here they are great mics and would work great for drum overhead, vocal, acoustic guitar, and many other things like percusion and shakers. At 150 they are a great deal and come with thier own shockmounts.
Beezoboy
thecongo;
That is almost exactly the reason I purchased a matched pair of SP B1's. I already had a MXL V67 which is about perfect for about 75% of the vocals I do but I wasn't satisfied with it as an instrument mic (Guitar, drum overhead....) & I also wanted another LD condenser with a slightly different flavor (a little less sibilance range hype) for some things & a slightly more extended freq range at both ends & being on a budget it seemed that from what specs I saw that the B1 should work nice to fill my need for a better instrument/drum overhead mic & alternative sounding vocal mic so I took a chance on a pair & so far am quite satisfied. I just did a test run a couple of nights ago with them as overheads & they sounded quite nice. Maybe not as good as a pair of MXL603s's but certainly better I thought than the V67. I was a little worried that being large diaphragms that their freq response wouldn't remain good over a wide enough pattern & this may be an advantage to something like the MXL603's but they seemed to do fine. I did a low tech analysis of their polar response by playing some pink noise through one of my speakers & recording it with the B1, holding the mic directly in front of the speaker & slowly spinning it. Viewing the spectrum analyzer in Samplitude of the recorded wave while it's playing, the freq response stays constant from on axis to about 45 degree off axis, at which point you can just begin to see the response above 10khz start to drop off just a little. From 45 degrees off axis to 90 degree off axis there's a rather rapid and continual degradation of freq response (mostly high freq loss) & some overall volume loss, both of which continue to degrade till they are at there minimum at approximately 135 degree off axis. Anyway without much further rambling, the main thing is that a constant response of +- 45 degree off axis should be fine for a pair of drum overheads if you keep that in mind when positioning & aiming them. The B1's vocal response was also about what I expected. Perhaps could use just a tad more sheen (They have a little dip in response around the 5 khz range), but anything I want out of it seems only a minor EQ adjustment away. The big + is it's clean & not harsh sounding (something you can't say about all the low priced Chinese based condensers) which makes me suspect the built in pre for the transformerless coupling is fairly decent.
From what little I know of the MXL2003 (V93) it also seems to me that it would work well in this multipurpose role.
That's all I know about that.
-Stephen-
The v-93 is just great.
I also like the sound clips I've heard from the B1. My impression is that they're both very good for the money, but the 93 is a little more expensive . . . and it sounds that way.
Drum over heads and a vocal mic? A pair of AT-4033's hands down IMHO.
