Strong
Hello, all. I'm new to the forum, and new to recording. I need help! The questions I have may seem pretty basic to all of you, but I'd appreciate it if anyone could offer some assistance. Thanks.
I'm setting up a home studio with a drummer who has Roland V-Drums with a TD10 brain. I need to know what the best way to record these is, as it will influence what sort of equipment we have to purchase. We're going to operate with a Digi 002. We're likely going to upgrade the converters, and we're also evaluating what we're going to need as far as pre-amps go. I know nothing about midi. Or much else, for that matter. I just know I want to record drums and get the best sound possible using what we have.
Specifically:
1. Do you have to record what comes out of the brain in a stereo right and left (ie your drum mix gets done in the brain and all you have control of in the mix is two channels)?
2. Can you make the brain send out, say, 8 separate tracks (each being a different drum), thereby having control over 8 different drum tracks in the mix?
3. Is the best way to get the signal from the brain to the track via midi, and if so, what is the physical set-up we need to accomplish this? If not, what is the best way (best signal, most control over sounds)?
4. If you thought the above was elementary/inane, try this: does the TD10 output have to be routed through a pre-amp of any sort?
5. Similarly, does the TD10 output have to be routed through an AD/DA converter? I.e., are we going to have to get an 8-track converter to properly record 8 different tracks of drums?
6. What would you recommend in terms of (a) AD/DA converters that would be up to the task, and (b) pre-amps?
7. Am I overlooking anything that I need to know in order to do this right?
I apologize for the rudimentary nature of these questions, but hey . . . you gotta start somewhere. And again, for anyone who takes the time to stoop to my level, I appreciate it very much. Thanks.
Specifically:
