theletterq
I did not get a chance to run the NTK through the DMP3. I actually sold the DMP3 and picked up
the Focusrite Voicemaster Pro. However, initially I am not getting the results I expected.
I am going to spend some more time tonight seeing if it was just some EQ settings or if the match up between the NTK and the Voicemaster works.
The C1 and Voicemaster Pro sounds really good with little EQ after the fact. The DMP3 and the C1 was OK, very EQ intensive however, after the fact.
Getting back to the NTK, because of its warm nature, I think it needs a fairly neutral pre to make it sound its best. It already has a significant amount of color and when you match it with a pre that has color it tends to be too much warmth. I may pick up another DMP3 to check the results as it was fairly neutral.
I am also going to try some soundcraft, mackie and behringer board pres tonight.
I wish there was a chart of experience that showed great mic/pre match-ups and vocal types. Something I could keep on my wall as a general guide. That's why I started this thread, to see others positive experiences in a sea of excessive variables.
