Stefan Elmblad
What's the best stereo A/D converter for about $500 ? Is there any at all ?
Stefan Elmblad said:Im looking for a A/D. An A/D that does not need the additional investment in a computer.
Recording Engineer said:Why would you usually want dither from an A/D?
Stefan Elmblad said:Which would sound better than to use a 16 bit A/D.
jmproductions said:Ok ummmm. First of all I own a an AD9624 and I think it's a nice piece of equipment. Yes it does dither to 16 but I think it is an analog noise shape process so you would not want to use it for multi-tracking as the noise would start to sum up and could be detectable. Really more for an analog master to digital process and I think that has been covered. I am not sure why you are as concerned about dithering 24 to 20 because most experts say that even the best converters are only capable of a true 19-20 bit accuracy. So let the other 4 bits just drop off, problem solved!! My advice is to worry more about your analog end and put your money there because it will make more of a difference.
Just my .02
Stefan Elmblad said:You're saying I can put a 24bit signal into a digital input that only accepts 20bit??
Stefan Elmblad said:And what do you know about my analog gear ?
